Re: hull extension in progress with picks
i thought i took more pics than this......but another milestone was reached tonight......the sides are ready to be faired........i dont think they are going to be a problem with them as they are allmost done now.....
noklu came by to lend a hand.....he decided we needed to some more work on the plaining surface..........so for the next five hours....we hand sanded every inch of the plaining surface.........
sanded .....sanded....and more sanding.....any how....at about 1 am he thought it was good.....and what an improvement.....even tho it was done....a lot of little detail was taken care of
so then we jacked up the hull.
we needed the hull higher so it will be easyer to fair it out.....rather than bending down with every longboard pass.....
the big problem with the side hull....is two big bulges where the mold moved.....i ground them down so far there was only a thin skin of glass....
they are in the same spot on each side of the hull
just before we left i added three layers of glass behind the hull so i could grind it down farther.........
now there is three thick layers of 40 oz material (each layer) so it will be plenty thick to grind down, and still have super stregnth after its ground to the desired outer smoothness........
tommorow night, our local football team is going against there arch rivals.....so i wont get on the boat till after the game.....but i still want to get 3 or 4 hours on it tommrow night
cheers
oops
