88 mercury wont start
Gary Harp
I have an 88 mercuy 175. I have had trouble starting it bout a month ago. I took the spark plugs out and wiped them down and she started rigt up. had the same problem the other day so I cleaned the spark plugs once again but nothing. It crankes over strong but it seems like there is no fire. Does anyone have an idea whats wrong or what I can check to fix it?<br /><br />thanx <br />gary
oldboat1
Re: 88 mercury wont start
Your note on the spark plugs would indicate that you have some fouling. Make sure your gas is fresh, and that you are using the right mix if it's a manual mix (probably 50:1).
