Deck coating / Turned complete restore
Status
Not open for further replies.
Woodonglass
In areas that won't be immersed in water for long periods then I suppose it would be Ok. You could also use Fine Wood Dust from your sander or a combination of the two. Back in the Day, people actually use Wheat Flour to thicken it.:rolleyes:
ahmincha
Cut off the hollow area where I want to mount the kicker Plan is to fill solid with pb and 3/4" ply then remount the exterior piece i cut off. Then I figure I can make up the difference with azek being is its on the outside and only needed for spacer Themn mount this
jigngrub
You can get sheet neoprene or rubber at Home Depot in the garden dept at the water pond supplies.
I'd use talc in epoxy resin, but not polyester resin.
ahmincha
Ok so my plan is to put a coat of csm on the underside tab it in with 1708 2 coat of csm on topside . Then I want to put a layer of 18 oz woven roving for texture. Does that sound alright?
Then I am thinking about gel coating I know to get it to look good will take a lot of sanding but I figure I only have to do the gunwales the deck I want texture.
My question is if I spray on the gel coat do I have to sand and buff it right away or can I do it over time while using the boat ?
ahmincha
Deck cut and 1.5 oz mat on one side. Plus I tried the bigger console off another boat I had seems to work
ahmincha
Fuel tank strapped in I did talk to tank manufacturer and he recommended I 2 part foam the corners in So I plan on doing that
ahmincha
Yours to corjen I tried commenting on yours the other day but as usual wouldn't let me
ahmincha
Thanks cor yours looks good to. I tried commenting the other day but it wouldn't work
ahmincha
Ok this is the console a little beat but I hope I can make it nice. The few areas of crazing do I just sand and fair over
Woodonglass
You're gunna need to dremel out all those cracks. If you don't they'll reappear. Are you gunna gelcoat it or paint it?
JASinIL2006
I used PB. Didn't want to wait 72 hours for PL to cure. I mixed my PB a little light on MEKP, so it would kick a little more slowly to give me time to work. I made it pretty thick, too.
Woodonglass
PB for your Decking. You still need to dremel that crazing and fill with mayonaise consistency fairing material made from resin and glass bubbles.
ahmincha
Thanks jas
Thank you also wood so pb then what type of screw do I need stainless
As for the crazing on the console just follow the crazes and then fill with mayo?
Status
