Woodonglass
- Dec 29, 2009
- 25,932
Yup ^^^ It has a lot of "Mass" and is STRONG cuz it has so much GLASS fiber but Not FUN to work with.
Look @ Post #100
Ax kicker, Your are right that they are two different planes. The outside flatness needs to be within 1/16" and the inside an 1/8". That's a different measurement technique than measuring total thickness. I'd lay a straight edge across each face, put a light behind it and see it it's writhing spec. If you're not positive stick a feeler gage in the gap to make sure. That's .0625 on the outside and .125 on the inside - that's how flat it needs to be. As far as thickness (21/8-21/4?) you could use a a caliper, plastic or steel; you can find them a lot cheaper than micrometers. I'd use one that does inches, hundredths of inches and thousandths of inches but for this, one that does 1/32" is good enough. If you get one and can't read it I'll help you; the common ones use a vernier scale, takes a little getting used to, the dial calipers are a little more intuitive but more expensive. A good machinist could measure tolerances like this with a six inch scale (a ruler). I found the air hammer really speeded up transom removal but if the hull was really thin it could be dangerous. Like you it worked for me. All of your pictures are showing up as x's, at least on my ipad. Don't know what's up with that. I have plenty of dry glass - in the transom and the tabbing for the stringers. Based on the pics I've seen it's not normal but it certainly does happen. I think it just means a little more grinding for those of us so blessed.
I just now figured out the time to be measuring is when you're clamping. Not making light of your situation - I'm sure it can be fixed, just don't know the best way. Pretty sure you don't want to use resin alone as a filler, it't too brittle and has no strength by itself. Someone will be along to help with that. Just to satisfy my own curiosity on the parallel tolerances thing, they don't have to be straight lines, say they were two parallel arcs (curved). If you check thickness and parallelism they'd be fine but you'd end up with a leak when you bolt on the inner transom plate and the gimbal assembly. I'll steal this from another post rickryder replied to. Pay attention to c and d below. Re: Transom Thickness Special Information Transom Specifications 22170 a - Transom Thickness-to Be 2 In. (51 mm) Minimum To 2-1/4 in. (57 mm) Maximum b - Transom Surfaces-MUST BE Parallel Within 1/8 in. (3.2 mm) Measured At Top And Bottom Of Cutout Hole c - Area Covered By Inner Transom Plate-MUST BE Flat Within 1/8 in. (3.2 mm) d - Area Covered By Gimbal Housing Assembly-MUST BE Flat Within 1/16 in. (1.6 mm) e - Transom Angle-10 to 16 f - Keel (If Equipped)-Remove 4 Ft. (1.2m) Forward To Transom The flatter the better Here is the thread in case you're interested.
No! Again, not sure what the correct fix is but you don't want do all the hard work on the boat and then do a hatchet job on that critical piece. First get some measurements then the experts can advise (probably matters if it's 1/16 out vs 1/4). Remember, on the outside only the area where the gimbal housing mounts to has to be correct so I don't think it's going to be much work to get it right.That cleared up a lot for me. I was confusing the difference between the panels being parallel and flat. So basically we have 3 measurements. Parallel, flat inside, and flat outside. Made my day to be able to help a little. Thought I had read whole thread but noticed WOG had already added the diagram for the Bravo. But that's what's so great about this forum; you can get that little "extra" bit of info to get you over the hump. I will have to take some measurements tomorrow. Im pretty certain that I am within parallel tolerance and inner flatness. I will have to check the outside transom tomorrow for flatness. Does anyone ever use sealant when installing the gimbal housing. I know it has gaskets etc but would it hurt to add some??? Considering the thing will most likely never come off within the amount of time ill own it ??? Any thoughts.
Sorry for assuming, it dawned on me that you hadn't touched the outside transom right after I submitted. It took me that long to post the second reply. Per statement d if the bellhousing area is within 1/16" you're good to go. They're only giving the spec for the sealing surface, rest of transom really doesn't matter. As a former machinist the best way I can think to measure it is with a straight edge, like you did and if it was close I might get out some feeler gauges just to be sure. Again, sorry about my confusion and I think you're good to go!
