Welcome Guest - Sign Up today
No announcement yet.
Trim limit wires...no where to be found
  • Trim limit wires...no where to be found
    Hi Everyone
    I could use a little advice please...I changed the Trim limit and sender switches on my 1988 Searay 230 Weekender with 7.4 Bravo....When I followed the lines into the boat the Trim limit wires were not plugged in...just dangling...which would explain no up on my trim....Ive looked everywhere and can not locate where they plug in...the schematic says to engine harness but there are no plugs anywhere....I'm beginning to think someone monkeyed with the harness prior to me owning....The wiring looks as if its been worked on....everything else works fine...I'm just finishing engine alignment so manifolds are off and visibility is as good as its going to get but I cant find the plugs...does someone have a picture they could share or detailed instructions...The schematic didn't help at all.
    Thanks D
    Re: Trim limit wires...no where to be found
    check the wiring coming from the trim pump,I think that's where my were disconnected.
    84 Beachcraft 229cid 3.8L V6 R Alpha 1.
    • #3
      Thats were the Trim sender plugs in...that ones good...I have down and trailer working...the Trim limiter is the one without a home....should tie into the harness somewhere...the wires look like they should be routed under shift lever and up near the fuel pump...but there are no un used wires available....unless your saying all 4 wires go back to the pump?..if so I dont see any spare wires there either.
      • #4
        Which controls do you have? On my old boat there was no provisions for a trim limit switch and they where just zip tyied up.
        83 Sunrunner 16.5 120 merc Alpha 1 drive SOLD 8/1/13
        1996 Crownline 202BR
        5.7l EFI 0f791070
        Bravo I drive
        GMC Yukon tow rig
        • #5
          Well you could run new wires. The trim switch wire is a purple white wire, should be somewhere back near the transom. There should also be a blue/white wire back there. That is the trailer wire from the control. What you need to do is connect the p/w wire to one
          switch wire and splice the other to the b/w wire.
          Terry
          87, 4WINNS H 190
          470/Alpha I
          • #6
            Trim limit wires go to pump. Sender to dash guage. My sender wires tie into shift plate terrminal block then through engine wiring harness to dash guage. Pump should have bullet connectors for limit switch wires.
            • #7
              Ok...I'm sorry...I misstated i had my terminology backwards....the TRIM LIMIT is plugged into the pump....
              1) Trailer function works
              2) down works
              3) Up does not work
              TRIM sender is the one that I can't find where to plug in....the wires look as if the are to be routed up by the shift plate....but there are not any unconnected wires in that area....the kit came with little wires to modify if you boat didn't have the plugs...it changes the wires to terminal type...Talked to a Merc Master he said one is ground and the other goes back to controls....all the wires coming from the sending gauge are black..so thats no help..
              84edH...can you share a picture of how yours connects? I don't know which one goes back to controls ..driving me crazy...manual and schematics don't show anything
              • #8
                2) down works
                3) Up does not work
                Sounds like you have a break in the blue/white wire connection, see wiring attachment
                Click image for larger version
Name:	Merc power trim 2012.jpg
                As for the gauge look for a Brown/white wire, it goes to the gauge. Here is a 4.3 diagram but it will be the same for you
Name:	4_3L elect diag.jpg
                94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
                95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
                07 Seadoo GTX
                Merc Adults Only VP Adults Only
                G-Dad always said "First Liar doesn't stand a chance"
                • #9
                  [ATTACH=CONFIG]219177[/ATTACH]
                  [ATTACH=CONFIG]219180[/ATTACH]
                  Found the Brown and white wire it attaches to a little blue box that says Mercathod ...maybe a stupid question but what the heck does that do and how do I wire my Trim sender to it?
                  • #10
                    Mercathode is the corrosion prevention. It has nothing to do with trim.
                    5.7l EFI 0f791070
                    Bravo I drive
                    GMC Yukon tow rig
                    • #11
                      I see....if the brown and white wire is my gauge why is it wired to the Mercathode? can I just run a junction off the brown and white wire and connect it to my trim sender?
                      • #12
                        OK I was wrong. The early models did have that wire to the trim position gauge.
                        5.7l EFI 0f791070
                        Bravo I drive
                        GMC Yukon tow rig
                        • #13
                          So should I use that wire?...does it need to stay where it's at?...there must be something i'm missing...there should be a plug or terminal to connect to?
                          • #14
                            Disconnect the brown/white wire from the mercathode and connect it to the trim sender. The mercathode uses an orange and a brown wire (no stripes) which lead to the boats anode. The other two connections go to ground and battery positive
                            Mercruiser Mercathode Wiring | Performance Product Technologies
                            07 Seadoo GTX
                            • #15
                              Ok..got it I'll try that. Thanks
