Hello,
I have a Mercury 800 Thunderbolt ignition and I believe the engine is 1970's era. The control box has 2 levers. I think the small lever is to control the throttle..correct?
Well, I took it out yesterday to test the boat and it will not go into reverse. I do not feel the reverse gear engage instead it revs up and the further I pull back on the shift level the higher the rpm.
The forward gear works but can go only max speed of 5mph or fast idle. The motor doesn't rev up to speed. If the shift linkage is out of adjustment, can it also affect the lack of power? There is old gas in the tank though.
I would like to go ahead and replace the spark plugs too. What is the recommended gap size and can I just get the spark plugs from an auto parts store?
thanks!
thanks!
