I pulled the lower unit on my mid 90's Force 90 HP, trying to figure out why it will not go into neutral or reverse. Right now, the prop ratchets when turned clockwise, and I cannot find a free spin while turning the forward/reverse shift shaft. I can spin the shift shaft all day long, and it doesn't seem to be doing anything with regards to shifting gears from F/N/R. I've tried rotating both ways, with no luck. Should I "feel" anything when I rotate the F/N/R shaft? Also, should I be able to pull the shift shaft out of the lower unit? I can pull the shaft out of the lower until, and feel it "drop" into what feels like the proper position in the lower gear box. However, I cant get it to do anything once its back in...
