- Jul 18, 2011
- 19,445
Re: 1991 Formula 242 Stringer & Bulkhead Repairs
I did a bit of wood work today, cutting and shaping the main stringer replacement sections.
First I installed the thru-hull in the bulkhead . . .
Then I made lots of saw dust on the back deck, as I cut the pieces for the stringer repair.
Then I installed the first piece of the lap joint on each stringer . . .
I used VE resin and a layer of saturated CSM in the joint so it would take up any gaps in the mating surfaces. I also used SS screws to hold the pieces firmly in place while curing. My plan is to just leave the screws there.
Once these lap pieces cure, I'll be installing the stringer section and then the outer lap pieces.
