1988 Sea Nymph GLS - 17'
  • Center Console
    Votes: 7 38.9%
  • Side (or Side by Side) console
    Votes: 11 61.1%
  • Total voters
    18
  • Poll closed .
jasoutside
Re: 1988 Sea Nymph GLS - 17'
Transom looks fantastic buddy! Gotta feel good getting that rollin.
Leave em on, one less thing to do, nice!
b.gagnon
Master Chief Petty Officer
I think that is the same hull as my boat....
Great Job!
Woodonglass
Pumps on. I rubber band saran wrap over mine.;)
jbcurt00
looks good!
+1 for Saran wrap....
magnumdeke
My pumps have been on and unsealed for a couple months with no ill effects! transom looks sweet.
rrumba
Ensign
nice progress there PM....... you are moving faster than a grinder to glasser.....
leave em in but they will still drip for awhile. i just left them in the same box they came in and turned the pumps into the middle with a disposable cup underneath them unless they are going to sit for a month or so before i use it again, but that never happened sooooooooo.................. but if it did i say same as WOG or a snack size ziplock and rubber band.
Decker83
Great choice on the marine plywood. Can't go wrong with it. Good looking work on the transom. How did you like putting the epoxy on without any glass or having to grind it between coats. :D
Glad to hear your transom came out flat. Keep up the good work.
GT1000000
Awesome job on the transom...
I can't wait till I own a heavier than water, tinluminum boat so's I can restore it as fast as you and Jas...:rolleyes:
Looking great, bro...:D
Have a speedy week...
Pmccraney
Thanks Guys; I am enjoying getting started on the put back...
Quick question since this thread is metal boat building for dummies: I've prepped the transom with two coats of epoxy with a light sanding in between coats... Now, I want to go ahead and slap some paint on it, since the epoxy (like vampires) hates the sun... Since this will come up during the rest of the build (deck, casting decks, etc...), do I need to prep the epoxy coated wood by sanding, etc.. before throwing on some primer and paint. Also, how long to does epoxy need to cure (set) before putting on the paint. (for what's its worth I did a search on the forum)... I think I am going to use porch paint to coat the transom unless you guys think Rusto would be better.
Thanks for carrying me through this.
~rpm
Woodonglass
72 hrs cure on the epoxy if the temps are 80 or higher. Double that if lower. If you can dent it with your fingernail then it ain't ready. Lightly scuff with 60 grit , Prime then Paint. Porch paint will work, check to see if it has UV protection too. But Hey...I'm a Glasser what do I know!!! and besides that
I'm just an...
Pmccraney
Almost there (tedious - but worth it hopefully!) - 9 blue sheets and counting...
bear_69cuda
Plenty of room in that hull for a center console dood! My Key West CC is 17'2" and I love it to death! You have more family friendly boats (ski and toon) at the parents right? Can't blame a guy for tryin right? :D Great progress my brutha....
m casey stock
Re: 1988 Sea Nymph GLS - 17 Foot
My old rig was quite similar to one you picked up. Overall, it was a pretty good rig and served me well for several years. I also had a 85hp Johnson on mine. It would get and go pretty good, usually topped out at about 38mph but I did get it to do 40 once.
I'm not sure if a prior owner had removed the full windshield from your GLS175 or not - or perhaps it is just a variation of this model.
Anyway... good luck on your project.
I like this windshield set up much better, NICE!
ezmobee
Been out of the loop for awhile but that's a great project you've got there. You're doing a great job so far. My Jupiter had a '73 Johnson 85 on it and it ran great and I could still get just about any part for it. CMC is your only real option for TnT though. I spent years looking for an OEM unit. Excellent work on the cleanup, transom and foam.
Trooper82
That is alot of foam strips! Almost there though....
magnumdeke
freaking sweet foam work!!!!!!
Pmccraney
You are a foam shaping MASTER!!!!
Aww, shucks, man, I learned it from watching you :facepalm: Seriously, thanks for the idea. It was a little tedious at the front where the hull shape was changing every few strips. Further aft, the hull shape is pretty uniform and not nearly as much "sizing" is required.
I'm not going to lie, your post actually gave me second thoughts... But, I'm over it... :p
As you know, those big windshields are not as prevalent down south, because the weather is so mild... but, I do like the "look" much better... Meridian and Gulf Shores, huh - another iboater in my area - fantastic... (spent some time in Orange Beach this summer - spent some time every summer growing up at Ono Island; wish Old River was still like it used to be -- Gulf Shores area is definitely in my blood!!!).
Thanks EZ, glad I finally listened to you (tinny with an outboard, right?). This project has been really enjoyable thus far...
Yes, 119 to be exact... About, 13 more and I'm done...
Thanks deke, I'm happy with the way it is turning out... I just used firm contractor's paper to trace the bulkhead and then cut it out and transferred it to the foam.... (oh and steady supply of fresh razor blades)...
Thanks guys... Have a good evening.
b.gagnon
I just wanted to show you the space +layout.....(Sorry for the bad pict)
