1987 Starcraft islander 190v?
87Starcraft
Morning Gents.
I’m about to start putting the transom back together. I am wondering what you all have done with the transom cap install. Regarding these small nails. Should I nail these back into my newly epoxied transom creating intrusion holes. Is there an alternative with rivets?
renns
Morning Gents.
I'm interested to see the suggestions here, as I'm at the same point in my project. The small perimeter nails/screws on my hull were steel, and corroded badly. Are yours stainless? They look in pretty decent shape.
87Starcraft
I drilled pilot holes in the wood and used small stainless screws coated with 5200.
Nice.. I will probably go that direction. 👍 Thank you for the suggestion watermann.BTW get any work done on your islander?
87Starcraft
I haven’t posted this because of the ugly workmanship but I got over that feeling. Here is my patchwork. The spot under the fuel fill hose was gaslogged and there was ALOT of corrosion there. The first attempt was with a beer can and jb weld, That was before I found this forum!
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
We have all done something questionable on our builds. As long as you are willing to learn it will be a fun ride.
That being said, I had a couple patches that I covered heavy in 5200 as well. It seems to get everywhere no matter how careful you are.
SHSU
Watermann
Not yet, it's still waiting it's turn. I did get a little fix with the SeaFarer project.
87Starcraft
SHSU
I backbuttered it entirely. Lesson learned!
87Starcraft
Nice. I read through jasoutsides thread recently. Helped with the insight of the tin addiction.
87Starcraft
I did a leak test this morning. Nothing leaking but the transom skin I’m still trying to get patched. 👍
87Starcraft
Patched up the transom skin and installed my fish finder mount. Thanks classiccat. 👌
Need to finish other patch. Also installed some braces to tie my stringers to my ribs.
SHSU
Took me a minute to figure out the honeycomb pattern on your patch was because it was old road sign. lol
SHSU
87Starcraft
Progress I believe, I got the transom skin Sealed up, got the bolts below the waterline most the 1/4” bolts are in and sealed. So I build power lines, I have gotten so much aluminum out of the trash. 👍
87Starcraft
First shot of paint on the transom. Picture of the runs and all.
87Starcraft
Bottom feeder prices (free)
87Starcraft
Hey sorry I didn’t respond to your question. I didn’t notice it. I don’t think they were stainless but they weren’t rusted.
renns
No worries, thanks for reply. Many of mine were rusted away from being submerged in wet transom. :-(
