So I have a couple gallons of epoxy resin that I will not be using. I was thinking of mixing up a huge batch and pouring it over this keel stringer. Any thoughts on this? Maybe thicken it up just a smidge so it won't flow all over the place.
Why don't you just use it on your deck and stringers? Or did you already buy poly for that?
Your poly won't stick to that epoxy. Will that be an issue? I wasn't sure if a stringer was going on top of that thing or not.
I guess you and I can't use weather as an excuse anymore, haha.
The brass tubes wont get brittle like the plastic, so you may want to see if you could borrow a flange tool from a marine shop.
