FORUM RULES UPDATED - - -
The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for . . . Forum RulesDammit man! That's not a boat, that's a colander!!!
Got that right!
I was considering putting a screw into that 1st real bad gash, and using a vice grip or pliers to try and pull it out as best as I can. I figure if I can flatten it out a bit better, than at least there will be more surface area for adhesion. Bad idea?
You'll find that Mineral Spirits on a shop towel (or your finger) does a nice job cleaning/smoothing out the 5200 right after install.
I'd goop up the mandrel holes in your rivets too.
Well done!![]()
On my 3 or 4 hairline cracks, is there a better method to repair other than patching? I'll patch if that's the recommended option.
Welding and patching are the two best permanent fixes, anything else will be temporary.
Oh yes. I don't want to be doing this again any time soon.Did you drill a small hole at the very end of the crack to prevent it from spreading??
