To Build a Boat (any boat)
lark2004
Re: To Build a Boat (any boat)
pics will be here by the time you wake up tommorrow
lark2004
ummm Dink..... why have you painted the boat......without the motor board?
Wimperdink
cause I felt like it :D ... I will paint the motor board seperate then bolt it in place
cpj
Ensign
Originally posted by Wimperdink:<br /> lol I know the feeling lark... we want pictures we want pictures... <br /><br />Dont let dave and cpj give you a hard time... your already well ahead of them in your project.
hey dink:mlm :D
djzyla1980
LMAO..... yeah mlm dink <br /><br />wheres the launch pictures...didn't make it did ya???
Wimperdink
Today I finished painting the bottom, built the motor board... tonight I will paint it and mount it.. tomorrow at 1:30 I will launch... my neighbor was begging me to wait so he could be there for the launch... I agree'd cause I need a camera operator too. contemplating the keelson weather I want to install one single one or two.<br /><br />I'm considering a windshield. :D
CalicoKid
Is there any way you could webcast this christening? Maybe payperview?<br /><br />You completely sealed the compartments huh? Safe bet :)
Wimperdink
well I spose now would be the time to admit since you asked.... the front is completely sealed... the side compartments are sealed on the outsides all the way around... the whole bottom inside of the cockpit is sealed... the only place I got lazy was the top of the cockpit on the side compartments... I layed plenty of glue on the stringers before screwing the top down but didnt actually fiberglass that seam. I got lazy near the end. All I have left to do is bolt the motorboard on... holes are drilled board is built, I'll just squeeze a bunch of 5200 in the holes before I mount the motor board. :D <br /><br /><br /> Wimps Chatroomis now open for the bored and restless.
CalicoKid
What I meant was that those compartments are more or less airtight and will act as flotation.
G DANE
ON that weedless motor wyou will need to have the trim pin all the way out, and maybe even have some extantion made, or it will press bow down, it creates uptrust. Is that a 5 or 6 HP ??<br /><br />Nice project, you really mowe along, how do you get the time.
Wimperdink
4 hp and thanks :) <br /><br />I was chatting with Dave and decided I need to make a straight up and down motorboard too.
joblo33
Nice work! I've been watching your progress since the day you started. You sure don't waste your time. I'd probably still be getting around to buying lumber :p .<br />I'd get another motor if I were you. I've got a couple of those weedless 4hp's and they're great for trolling but aren't very quick. A 9.8 Merc or 9.9 JohnnyRude would be cheap and way more fun on that thing.<br />Eric
Wimperdink
Originally posted by Eric B:<br /> <br />I'd get another motor if I were you. I've got a couple of those weedless 4hp's and they're great for trolling but aren't very quick. A 9.8 Merc or 9.9 JohnnyRude would be cheap and way more fun on that thing.<br />Eric
I may get another motor yet.... I'm not sure what size though... Then again I may wait until just after xmas when many need money and go shopping on ebay and swap meets and buy a small array of motors to fit this and future projects :D If I get 10 mph out of this combination i'll be happy. :)
CalicoKid
Is the geargase not 90 degrees to the driveshaft on that motor?<br /><br />Nice work, looks fast from the angle of the first photo.<br /><br />Are you going to put in the steering board, or anything to hang on to?
lark2004
<br /><br />it's a start, I don't have as much time to work on things as some....
Wimperdink
Calico no its not a 90 degree lower unit... it faces down a bit.<br /><br />
<br /><br /><br />Lark, right on.... just keep em comin as you go... I think you have the same measurements on the sides of your cross piece as I came up with. Those measurements screwed me up... made me move the cross piece back some and had to compensate everywhere else for it. :) I'll explain further when you get moreinto the assembly phase.
Wimperdink
I'll be back later with the rest of the story... unfortunatly 5 minute camera lesson should have been a 20 minute lesson... I've got next to no good material with the pictures. Here's a few anyway.<br />9 mph top speed. Needs tweaking.<br /><br />
<br />
<br /><br />
<br /><br />puts out a massive wake for the size of the boat in a turn. <br />
Mark42
Looking good! Maybe there is room for twin 9.9's on the back?
