Rehab SportCraft 222 1983 deep V hull cuddy walkaround
chevymaher
Happy 4rth to you to and everyone else.
I am prepping the grill for steaks and corn on the cog and waffle cut potatoes.
And i got a bunch of fireworks for the little man tonight.
kcassells
Completed fairing so far 2x on sides and rear of transom. Finished with wet sanding this morning. Took a chance and decided to apply Rustoleum clean metal primer Woodonglass . I did 2 coats and will let it dry.
weather is unpredictable. Turned out pretty darn nice. Not a major issues with profile of finish at all. Some pin holes but an easy fix.
Anyone have a quick dry epoxy base fix for the pins holes? Fairing takes a long time to cure.
back to the deck. Glad the rain is holding off.
Click image for larger version  Name:	2018_0701_040203_002.JPG Views:	1 Size:	444.0 KB ID:	10767143Click image for larger version  Name:	2018_0701_040145_001.JPG Views:	1 Size:	522.3 KB ID:	10767144Click image for larger version  Name:	2018_0701_033138_004.JPG Views:	1 Size:	418.3 KB ID:	10767145Click image for larger version  Name:	2018_0701_033128_003.JPG Views:	1 Size:	301.4 KB ID:	10767146Click image for larger version  Name:	2018_0701_033107_001.JPG Views:	1 Size:	298.1 KB ID:	10767147Click image for larger version  Name:	2018_0701_033116_002.JPG Views:	1 Size:	449.7 KB ID:	10767148Click image for larger version  Name:	2018_0624_061045_001.JPG Views:	2 Size:	639.1 KB ID:	10767149Click image for larger version  Name:	2018_0624_044812_001.JPG Views:	2 Size:	780.1 KB ID:	10767151Click image for larger version  Name:	2018_0701_032811_002.JPG Views:	1 Size:	581.1 KB ID:	10767153Click image for larger version  Name:	2018_0701_032759_001.JPG Views:	1 Size:	614.0 KB ID:	10767154
sphelps
Looking very nice Kc !
I have filled pin holes just using the primer , preferably high build , with a squeegee.
kcassells
We'll see major storm just blew thru. Going out to hope it was dry enough to take the rain.
kcassells
Ya hooey!!!
All stuck. Wiped right off with a towel. VVVVeeerrrryyyy Happy! Whew!
sphelps
If your using the rusto just use there hb .. Are you using rusto for the finish paint ?
Not advised to put epoxy filler over primer I think . You would need to take the primer back down to glass .
‘I think PPG has a high build epoxy primer IIRC . Or maybe it polyurethane.... I’d have to check ..
kcassells
Thanks Sam....still confused. LOL! No rush or Biggy we'll get it right. ;)
Their so little might even squeeze bondo in there and move along. Don't tell anyone.
kcassells
For finish paint I will be using WOG's formula but using Kirby's Paints. Large selection of colors to work with. I used them on my transom and am very pleased. :D
So I now will clean up the boat and begin prepping the floor for glass. I'll have plenty of time and sure will have more pin holes to contend with.
Their are only a few pinholes. I learnt a trick. After your final sanding, roll a coat of resin. Prior to primer wet sand 220,dry and prime. fyi.
sphelps
If you have the pin holes after your prime coat . Use the same primer and squeegee it into the holes . If the holes are deep it may take a couple coats . Sand it out and see if that helps . WOG taught me that trick years ago ...
kcassells
Thanks Sam,
You are spot on with that concept. Their are so many tricks to learn. :D
I went back out this morning and did the cleansing. Getting ready to fair, fill, sand and glass. Since I got past the deck/gunnels/flush deck I don't really see the glassing of the deck being an issue. Other than the usual fill, sand, perfections, do again and glass.
2018_0702_050326_002.JPG2018_0702_050317_001.JPG2018_0702_050246_002.JPG2018_0702_050243_001.JPG
kcassells
Hmmmm…..Nothing but this!!
oldrem
Dang, we're finally having decent weather - but leaving in the morning for 6 days in Fountain Colorado
