Cougar_15
- Aug 11, 2008
- 93
Re: Project Sea Sprite
Thanks for all the great advice and support, as always! I would not have even known where to begin with out it! I'm anxious to get back to working on it, sitting on the shore watching everyone out on the water is tough...
On another topic, I was really intrigued with the idea of using 4# foam (instead of stringers) to add strength to the hull, that was talked about in Driven1's tread (MFG Gypsy 15 Tri-Hull Restore). As far as I can tell so far the stringer in the Sprite seems pretty solid, what do you guys think of the idea of leaving the stringer as is and filling the space on either side of the stringer with 4# foam?
jcsercsa, did you glass the deck to the inside edge of the rail or did you take the glass all the way over it?One thing on the side storage if you leave them in [ i did on mine ] when you put the deck back in you will have to cut it , I did on mine , had to cut it in 4 peices instead of 2
