coolguy147
- Jul 14, 2008
- 2,817
is the self-etching primer zinc chromate?
I decided on using Fiberglass resin to seal the wood. I use the hardener with it no matter what?
Maybe or maybe not! Read the label on the can and the link below:
http://forums.iboats.com/showthread.php?t=251095
Is it necessary?
Or, you can do nothing and see what it looks like in another 50 years! My turn to LOL.
Did i get the right stuff? Fiberglass resin? Is that epoxy or am i on the totally wrong path lol........
Coolguy will probably actually still be around for another 50 years......maybe with the same boat!
Two kinds: either epoxy or polyester resin. Either will work for what you are doing, but don't mix them. Once you start with one type, continue with it.
Yeah, I know he's a young guy! Tashasdaddy made a big deal of trying to help Coolguy since he wanted to learn this stuff.
I'm guessing I have polyester resin?
I know all wood warps but if i let it lean on something will it warp even worse?
Yes, leaning that sheet of plywood up against something will not be good for it. Lay it down flat on some (3 or 4) 2X4's out of the rain!
Out of curiosity, what exactly is the purpose of the glue? Just to hold the wood together? I mean couldn't I do that with screws?
The glue creates one solid mass out of two pieces and spreads all the forces applied to it evenly...a bunch of screws can't do that and the more you put in the more holes you have to seal up so water can't get into it and start the rot...
It is actually best if you can clamp the pieces together without using any screws, but for that you need "Wog Clamps"...
check "woodonglass" sig for the design...
Also, make sure the glue you use is waterproof...PL Premium {takes a long time to dry}, Titebond III or Gorilla Glue {ready overnight}
I think I may have cut the wood wrong.....Well, after sleeping I woke up thinking about whether the ends go in the cap. With the short shaft design the wood goes into the gunwales and I don't think it's going in now. Ill have to check that out.....The pieces did go in there nicely though
