Re: Orlando Clipper Customization/Restoration
I believe you should consider drilling the hole out to one-inch diameter to get rid of the threads so a one-inch snap plug will seal correctly! The iboats store sells them for $3-4 depending on if you like brass or stainless. Good luck!
Seasense Brass Snap Drain Plug - iboats
I'm using a 3/4 PVC drain plugs with 2 o-rings but it still leaks D: I measured the hole and it came out to .950 something. Would a 1 inch snap in drain work even though there are threads on the things? The threads are about gone D:
