Re: Orlando Clipper Customization/Restoration
5200 is intended for "permanent" installations and is difficult to remove if you ever want to do anything over. 4200 is considered "semi-permanent" and much easier to remove. You will have to decide which one to use.
I am unclear what you mean are "angle braces that go to the bottom of the boat". Are you describing transom knees (triangular braces) that connect the transom and the bottom? If not, we need a better description or, better yet, close-up pictures!
How should i seal the angle braces that go to the bottom of the boat 5200? It's kinda weird but the 5200 i used on my new bolts didn't seem to hold the bolt in that well?
