Re: My tri-hull transom replacement w/ pics
I have accomplished a few things in the past couple of weeks. I managed to get the engine mounted, however it will have to come back off when I paint it. I am loving the power tilt. It works great and I am looking forward to wiring a remote tilt switch in the aft coaming panel. For some reason I think that it is cool to be able to tilt it for trolling and when I load it on the trailer.
Before circa 1977
After modern machine
The hot rodder in me loves the way 20 horse power over stock looks on the back of my boat. This boat was quick with 70 hp, I am looking forward to seeing what 90hp will do. Me likee
The steering cable was a comedy of errors. I purchased a Teflex NFB kit that came with a new NFB helm and the cable. First time I ordered the wrong length 14 foot cable. It was two feet too long. I sent the cable back and they promptly sent me one back. New in the box 14 feet long! Again, wrong length. I contacted them again and after some apologies from the bonehead who sent it, I got another new cable. This time it fit neatly under the gunnel and was perfect length.
After some planning I finally came up with the mounts for my battery, a battery switch, main power breaker to feed the boat fuse panel going under the dash, a troller breaker and a main ground buss. I want everything to mount neatly hidden just under the gunnel. When I am done, all you will see is two neat cables and the battery box. I hate messy wiring.
The battery mount still needs glass and gelcoat. A black battery box will sit in place here held down by the two studs and removable knobs. A very tidy setup.
I use the K.I.S.S. method. The mount is a simple piece of ply routed over for fiberglass and two stainless 1/4-20 studs. I cleaned up the spot where it is mounted and bonded it to the deck with a thick coat of epoxy. I cleaned up the epoxy from around the edges and I will use poly resin and surfboard cloth to glass it over followed by gelcoat. The switch plate is done the same way except it will get glassed with epoxy and I will repair the paint in that area.
I have most of the wiring. All marine tinned wire and top quality components. I still need a switch panel for the dash and some lighting and I am ready to string wire.
