Woodonglass
- Dec 29, 2009
- 25,933
Re: MFG rebuild getting started pics
Seats are gunna look great in the boat. Guess surging the pump didn't work. You might try disconnecting the fitting from the front of the pump and running the garden hose down as far as you can and then seal the pipe with a towel around the hose and see if if will reverse blow out the obstruction. If you have a lot of 90? joints then prolly not much you can do. Do you know a Nurse or a Dr. that you can borrow a Stethascope from. You can sometime LISTEN and hear gurgling at the point of an obstruction.
