Woodonglass
- Dec 29, 2009
- 25,931
Re: MFG rebuild getting started pics
I covered the entire top and sides of the foam with the 1/2" Rayon Batting, not the bottom. I then Sprayed it with 3M Super 77 Spray Adhesive and Glued the Plastic on it. Kinda stretched the plastic over it and smoothed it all out and rounded it over the edges. Made the Vinyl fit really well.Thanks Wood ! The ply template is a little larger than the seat backing. The foam is about 1/4 to 3/8 larger than the wood backing. My concern was keeping the cut somewhat square with as thick as the foam is. Did you put the 1/2" poly backing over the whole seat or just on the back of the wood backing ?
