MFG rebuild getting started pics
sphelps
Re: MFG rebuild getting started pics
I stopped in Silver Springs once n my younger years...Didn't have a camera...went out on one of the glass bottom boats..man that is some clear water...and the bass...huge!
I have not been there in prolly 23 yrs. Need to make it back down there sometime..
sphelps
I DON'T wanna be around if that BOW eye ever Pops out. I like that Lift eye too! Very unique feature.
Thanks Wood ! I need to cut the shaft down about an inch. I have never re threaded anything like this. Could I buy a tap and dye set and just do it myself? Or maybe find a mach shop around and let them do it..
sphelps
Back from a splash just not with a boat! Here is a link to my photo bucket . yea I'm to old for this kinda stuff but you may get a chuckle or two.. Lots of pics and vids from our neck of the woods..
http://s1231.photobucket.com/albums/ee507/Sam1005boat/#!cpZZ2QQtppZZ16
Woodonglass
I see NO reason why you could not tap those threads yourself. Some machine oil and a good vice and a tap and away yu go. Tap it first then cut to siize.
sphelps
Thanks Wood gotta pic up some more acetone so I'll swing by h/f and see if they have a tap there.
OK time to get back on the project.. Doing some prep on the cap gunna start with 100 grit then 150 . From there I have some 220 so I guess I'll use it. Sound ok before prime?
I've been thinking on the gellcoat on the deck . I want to transition from the valspar to gellcoat at about the blue tape line. Should I just cover the gellcoat area so not to get any primer on it. I want to paint the deck last. Will the gellcoat harden to quickly to just tape the transition. I also have these textured step pads that I may gellcoat white. You think that would look silly?
Also can you apply small amounts of the 3m premium filler in between coats of paint if needed for touch up without sanding all the way down to glass? If not whats the best option over primer or paint?
Thanks!
Trooper82
SP, I would take a file and see if you can "cut" the shaft where the threads need to be before going and buying a Die to cut the threads. If it is hard, you will at best have a very difficult time cutting threads- or worse just break your Die. If you can mark it with a file you should be good to proceed.
Looks like everyone is having a good time on vacation!
sphelps
Thanks Troop I will check that out before I buy one..
craigweaver
SP, I finally just got caught up on your thread. I love the new splash and seats progress! That hoist eye is pretty cool, too bad it's not more adustable already. Congrats on 25 yrs, me and my mrs just celebrated 8 in April. (second time around for both, it seems to have worked this time :facepalm: ) The vacation looked like fun!
sphelps
Thanks CW ! I guess at 8 yrs your prolly pretty much over the hump..;)
It's been raining big bucket loads down here the last couple of days. Gunna try and shoot some primer sometime tomorrow. That is if I ever get the splashwell area ready to go . It's kinda kickin my butt a little. As long as I am in the garage I should be ok priming ya think?
He's got the right idea with this weather I think..
sphelps
What do you guy's think of the idea of stripes?
I know it's a bad paint job but you get the idea..
sphelps
All the kleets and bow light were white so I will repaint them white. I think that would accent the stripes well.
sphelps
Just a little more sanding on the splash area and I think she'll be ready for primer. I rolled it outside and will give it a quick wash and dry in the morning. I also need to do a clean up of the garage and reclose it in for the painting. With all the rain the mosquitoes are gettin kinda bad. Should be able to get the first coat of primer on tomorrow hopefully ..:)
Trooper82
I like the stripes sp. i see I am not the only one to do work boat on vacation :)
GL on getting the primer on.
sphelps
We have battle ship grey ! Took right at 4 and a half cups first coat..
A little touchup here and there but I think it looks decent.. The worst part was keeping the hose off what was already primed getting in and out of the boat..
Woodonglass
Make a couple of Clothes Hangar Hooks and screw em into the ceiling to manage your hose when you do the final coats of color. The Stern Looks FACTORY. NICE!!!!
jbcurt00
Splash looks like it's always been that way:)
Primer looks good & even! Outstanding:cool:
Trooper82
That seating area on stern looks fabulous...you should be proud...you did right good...
The primer looks great too.
Jon Sob
Master Chief Petty Officer
Hey sp .... that is just amazing how that stern came out. A+ job my friend!!
sphelps
Wood,
Yea I was thinking about hanging the hose from the ceiling about the same time I drug it over some wet primer.:facepalm:
I will set something up next go round.BTW it is factory . IBOATS factory !:cool:
Jbc, Troop, Jon,
Thanks gentlemen ! I also sprayed a piece of plywood so I can start the color match process..
Its been a long day fella's see ya!
