hull extension in progress with pics
Status
Not open for further replies.
drewmitch44
Re: hull extension in progress with picks
Glad to be on another page before we get a bunch of pics of dudes with chainsaws in crappy little boats. I got a bud that was going to take a pic with a boat that there was a tree growing through that was going to take a pic of the cleanup and post it on here. It would be a butt pinch-fest at that point.
oops!
any time bill..
rob...i was thinking of the high section....the only problem is , if i lived when i hit the water....it would be so cold right now, id freeze to death...lol....
yep yer right....better done now than on the water....i cant imagine doing this on my back.....i would have pulled out the chain saw by now...!!!!
ondarvr probally saved the project by suggesting and guiding the flip.
i just hope we can get it into shape soon....i thought it looked good !
Tacklewasher
Just read through a bunch of this thread. Not all I admit but enough to know that:
a) oops! is nuts
b) oops! is in the same town as I am
c) oops! probably has more refined taste in beer than "Corona".
d) oops! would probably enjoy a Tree Beer. Something like a Thirst Beaver
e) I'd love to see this thing in real life
d) I'd be willing to donate a cold 6 pack of Thirsty Beaver (minus the one I enjoy) just to be able to see this thing in real life.
oops!. I'm in Rutland and am serious.
(Oh. And I should show you the job I did on my boat converting a stern drive to an outboard)
Squid Billy
:eek:
Titanic .....
redfury
You can count your lucky stars someone happened by and noticed the misalignment oops! Like you said, it would have been a nightmare if you had gone over everything, finished it and got it on the lake, only to wonder why it pulled to the left/right ! :eek:
oops!
tackel washer.....you have a pm ! :D
1. yup im nutz !
2. the boat is by prospera place
3. i used to drink tree beer but the wood chips kept gettin stuck in my teeth
oops!
or round in circles !
can you imagine having to re-do the hull after.
the boat is back on track......lots of work done on it.....
now i know its running true......
update comin in about an hour....
oops!
ok....where do i start...!!!!
these pics are fron the saturday night marathon........
i thought the strakes were good, so i started to glass them in.....this is a really thick csm.....1.5 oz (at least)
as uaual...each peice of glass is pre cut for the application
this is the other side compleated....
a few years ago, i backed into a short pole in the back alley of my store. the area was repaired....(patched) so i wanted to re do it, properly.....i had some left over resin from the strake lay up, so i used the rest on the transom area
after it cured, a quick grind job for clean up....and done.
Bigdaveaz
Where da Pix?
jcsercsa
Hay buddie , If you still do jump you could fill your pockets with them ping=pong balls !!!! hahahhahhahah man sorry to hear your having problems !!!! Did you do any fishing when you were out the other day ?? John
oops!
getting back to the strakes......in this pic....if you look really closely....you can see a slight waver in the strake....
too much......!....the strakes need to be paralell with the chines.....and they were out just a tad......not good enough
you can also see a waver in the chine......its not anywhere as bad as it looks in the pic....(the poor light in the shop makes good pics difficult)
here i was starting to cover the main keel area with wraps of matt matt 1708 layup........
see that old blue gell goat?.....it had to come off later......i didnt think it would be a factor as the glass bonded to it well before.....but i later decided to grind out the area and remove the gellcoat totally......it was late and i wasnt thinking clearly, or i would have just ground it out right then !
these pics were from a few days ago......
after i realized there was a problem....i contacted dale from svfarah boats....
dale is a salty ol dawg, who started glassing boats on the west coast years ago......dale jumped on and helped me get straightend out.....
we re ground out the strakes.....(i really wasnt out by much)
and using a 12 foot legnth of heavy angle iron we placed it next to the strake taped it in position....(tuck tape) and back filled up to it.....
this produced an amazingly straight strake......
again...the pics are bad due to light....but these things are dead straight....and perfectly symmectrical to the hull
the alignment from chine to strake is 14 ins
ill get more detailed photos of the process of building the strake today, including the angle iron....the poly fair stuck to the iron on the test section....so i wrapped the iron in tuck tape.....(the surface of the tape is really waxy)....it worked like a charm.....the iron came off the strake perfectally and left a smooth glossy finish.
in this pic you can see the sharpness of the chine and the strake.
for a proper fair job in large surfaces....you need a point of reference.....somthing i did not have before when i was doing it by my self.
the angle iron gives us a point of reference, one from the chine, another from the strake. them all you have to do is fill the low spots....
ill have more tommorow, as ther is a lot more work done to the hull, i have a full camera full.... including the keel being straightened
cheers
oops
Bigdaveaz
No Pics!
jcsercsa
They look really good, i will have to rember that one , its kind of like the coner piece when dry walling, I can get some really nice corners on them !! to cool buddie keep up the good work !!! John
Robj
Glad things are working out. Helps to get a little help from the Pros. Will probably get back up there in two weeks for a few Coronas and maybe even help out a little if needed.
Have a great day,
Rob.
oops!
im not sure why your not seeing the pics.....
what do you see?...a small red x ?
post in the problems using the website forum.....way down past the manufacturers forum
redfury
no pictures is usually just a lag from uploading and then posting on the forums. I've seen that when I've jumped right in after a picture update. No pictures, no code, no red x. Came back the next day and they were all there.
Be patient guys. If you see a description but no picture, look at the time oops! posted and come back later to see them...they'll be there.
The angle iron trick is slick! Kinda thinking you are glad that someone eyeballed your work and said it sucked, aren't you? :D She's standing tall and straight now, there won't be a doubt how she fairs on the water now! :cool:
oops!
thats exactally right red.....
when i was doing it my self....there was still a hook in the hull.....i thought .....well the glass will take that out i think.....and if i get up on plane...the plaining area should be behind the hooked area.....
just guesses.....hope this and hope that........
well.....when i post the latest pics...youll see...its straight...no guessing or hoping.......the discussion last night was.....if we give a softer edge on the strakes, it will soften the ride in heaver seas....
the fairing is going well....we are using longboards.....(hand held sanding blocks)....the work is so hard that you can go full blast for only 5 minits at a time....by then your sweating so bad you cant help but stop for five minits...
(ever seen a wet tyvec suit? :eek:...they stick to you)
ive got big blisters on my palms pushing with all my might on the long board.
but we feel that by sunday...we will be ready for the final wrap of the hull.:D
fishie
Lookin good bud!!! Glad you got everything straightend out! Do you know if the bondo brand poly is waxed or unwaxed? It has less of a sheen than the elmers stuff i was using it seems to saturate the glass easier...hmmm...:)rolleyes: sorry, I swear I have ADD!!) Anyway, cant wait to see it go to paint!! Keep the pics comin!
oops!
the farring compound is unwaxed.....but when placed against a hard surface to cure, it has a really good shine...(the angle iron with tuck tape)
i forgot to add....the tuck tape is becoming really handy....we have used a full roll of it so far to hold things in place temporarily.....it is really strong...and the waxy surface is proving a snap to break the molded surface...
the pics in detail will follow soon
fixb52s
Hey Oops, have you considered an air file from Harbor Freight? They have a long one that might save you a few Tyvec suits! Then again, all this sanding will keep you in shape in the hockey off time. :D
Status
