Re: Removing a 18hp fastwin waterpump
Dittos KB.It better be a bolt,otherwise,somebody's replaced it with something that should not be there.The whole lower unit,with driveshaft and the water tube, should drop down a couple of inches by itself, just like you said? Right?<br />You gotta give it a little help.Twist it,turn it (gently) a little and it loosens the shaft up from the splines way up in the powerhead. I actually turned the flywheel a tiny bit and the thing fell right out.It's mainly held in at this point by all of the accumulated goop around the shaft and the keeper.It'll pop out like nobody's business on ya, so be careful you don't drop the thing on the cement under it, otherwise you end up with a bent lower unit.I actually anticipated this and put a nice heavy towel under it.Yay for me.Oh, and make sure the thing is in neutral when you do all of this.If you have to use something to pry,a broomstick does the trick.Anything but metal!<br />I have the same motor,with the electric start (times two).1958 Fast Twin 18hp.<br />And by the way, I have everybody whipped hands down as far as lower intelligence when it comes to outboards, so you have no chance of whipping me on that aspect, so don't even think about it.. If brains were dynamite, I don't think I could blow my nose. The only reason I could mention these suggestions is because I have two of these things and have done exactly what you're doing now.Good luck, Dude. Keep everybody posted.By the way, when you put it back together, there's a tiny little rubber o-ring that goes right on top of the driveshaft above the splines.DON'T forget to replace it if it's not there,which it won't be.ACE hardware.18 cents.
