Re: hull extension in progress with picks
ok.....first thing i wanted to do was try wize ones method of capping....
i wet out the area of the stringer fully with a hot mix.....then i wated till it was allmost at cure.....(really sticky not wet sticky)....
and streched the fabric over it.
i rolled the fabric into place firmly so it would fully cure there......i placed the top as best i could... rolled it...then streched the sides.....rolled it...then the curve at the bottom....and rolled it out....
i was worried about micro bubbles after curing, so i rolled it 3 times. there was no way i would know if i got all the bubbles out, but i did know that the cloth could not move....
in the mean time i re cut some stripps for the other stringers and started glassing. this will be a cap method.
each one section took one hour including shaping , aceitoning and glassing.
the sections are 50 ins...and 2 layers of 1708 per side for a total of 4 layers
that took till 1130 pm......
i did the experimental section at 5 30 pm. so it was time to glass it.
it doesnt matter what you do...every time resin hits glass, the glass expands as the resin saturates it.......
you can see the top of the stringer had a few contact points with the glass
the other thing (using this method) is that you can never be sure all the air is out....see bottom of stringer.
if i had added a layer of 10 oz matt at the top of the stringer...(as ondarvr suggested) during wet out...it is possible totally possible that i could have gotten a good bond at the top of the stringer. hovever the bubble problem would still exist.....
i took these shots because one poster was having problems with 1708 on vertical surfaces.
if you cut 1708 with the grain of material going upward on the surface, it is really hard to keep the fabric from flopping over and unraveling.....
i had cut some on the vertical and glassed it in position
you can see the mess it was...that section took an extermely long time to roll. it was a real..... Pain In The .......(pita).
just behind the shoddy stringer is a properly glassed stringer with the grains of the glass running legnth wize with the stringer......it took only 15 minits for that peice of cloth.
the three main stringers are now double glassed...and tonight im going to start on the motor housing stringers and the two outward stringers i added.
cheers
oops
