Re: hull extension in progress with picks
ok.....after the relitaves left....i got to do some work on the boat...in between being chased back into the shop by severe thunder showers...lol
here is a over all shot of the boat right now.
and here is the steering wheel that noklu was talking about....
lol....i like it.
by the way......yesterday i had to make some under the dash supports and do some more playing with the gas tank.....
this is a piece of under dash support....ill post pics of the whole thing soon.
ok....so my job today was to install the shifter and a few other things....
the first thing was to cut out the shifter hole....
a lot of times....they give you a template for this kind of stuff.....but unless you have tracing paper you have a hard time getting the template on the piece to be cut....
i like to use painters tape....you can still see thru it just tape the template right on the surface
for this install...i used a drill....a rotary saw....and a jigsaw.
here i had allready drilled the four mounting holes
my rotary saw had the wrong bit in it and was working really slo....in fact burning the glass....not cutting it....so i switched to the jigsaw and the drill......it is really hard to make the sharp corners with the jig saw.....so i drilled holes at the corners....allowing the blade to turn properly
in no time at all.....its done
