Re: hull extension in progress with picks
I notice you have mat there....maybe cloth will bring you joy on those 90s
hi coastal......
cloth is really bad on 90 deg corners.....espically if over a distance...
if the corner is not perfectally straight and the cloth is not lined up exactally with the weave of the cloth.....you will get air...
but there is a way!!!!
ok......
i gotta speed up the updates cause its getting down to the nitty gritty and the posts are far behind.
if im not at the hospital or hockey games im at the boat
the arm consoles were a challenge glassing.....i needed stregnth but i also needed stiffness.....
the only way to do it was to lay a strip of csm an each flat part with out bending the matt over the corner
then when it was still wet....i added a 1708 layer over each flat part.
i let that start to kick.....and when it was still sticky......i started ripping matt!.
the idea is to break down the binder that holds the glass togeather.....the individual strands of glass will make the corner.
when you rip the glass, you can feel the binder break down .....this matt is 1.5 oz.
that was laid out and glassed
