Re: Here I go again!! 1995 Sea Ray 220 Signature Deck and Stringer Restoration
Nice job on the boat. I am currently doing a restoration on a Regal ski boat where I am using composite material. Not sure how Red Guard would work (never used it before) but I know that epoxy resin it highy reputable for waterproofing and can be applied over wood or polyester laminate.
Has anyone figured out how water get's under the deck to begin with? The only two open compartments are the bildge area and the ski locker....correct. In theory water should not be able to get into these other below deck compartments, but we all know it does. I removed several extra pounds of water soaked foam in compartments that were sealed compartments under the deck. I have heard that the water can seep though any screws into the compartments and therefore anything screwed into the deck should be sealed with 3M 5200. I also believe that in an old ski boat the carpet gets soaked, the polyester resin over the plywood gets cracked and water then eventually finds it's way in.
Does anyone have anymore to add on this subject or can you point me to another thread that explains this problem. I don't have any wood that can rot, but I do have flotation foam that I'd like to keep dry.
thank you
I am going to look into that filler neck for sure. Thanks for the great ideas.
I had another idea today and I wanted to run it by everyone. When I rebuilt my shower I used a product called redguard to waterproof the shower. Redguard is an elastomeric membrane that you brush on and it dries hard as nails, but stays flexible. My thought was to slather this stuff on all the stringers and hull after I do all the glassing, but before I pour in the foam. I think that just might give me the real protection against cracks letting water sit on the stringers. According to the technical sheet it will bond perfectly, and it is rated for outdoor use.
Thoughts?
thank you
