Deck coating / Turned complete restore
Status
Not open for further replies.
ahmincha
Re: Deck coating
Re: Deck coating
Hello jc that was my plan I thought I would cut a section of deck out under the center console
jbcurt00
Re: Deck coating
Re: Deck coating
Yes I did soaked rag with acetone let it sit on boat and It did not come off
Boat was made by traveler out of Tifton Ga have look on internet not a lot of info manufacturer out of business
This pix for your 1st post looks like the white & blue were applied AFTER the boat was assembled & the rub rail was installed:
attachment.php
So whatever it is, if you want to reuse the boxes, you've got to get down to good fiberglass to tab them back in.
But yep, that's for all after you get done checking below deck.
ahmincha
Re: Deck coating
Re: Deck coating
Ok I have a new ? Can i cut out the floor within 2 " around the storage lockers leaving the lockers ad if every thing is o underneath tab the floor back in or is that to much existing floor to leave
jigngrub
Re: Deck coating
Re: Deck coating
That's where I would start, it'll get rid of the majority of your wet/damp decking and give you a good look see at what you have below deck. If you need to do more later you can probably just lift the cap off with the compartments attached. This would be if you need to replace stringers.
ahmincha
Re: Deck coating
Re: Deck coating
Thats the problem jig there is no cap the gunwales are single layer fiberglass I was not sure if I cut out around the lockers that it would be Ok to tab back in that far away fro the sides for strength
jigngrub
Re: Deck coating
Re: Deck coating
At the risk of terrifying you with the words 2 part expanding urethane foam, I'll show you the strongest fix for that:
The foam will support the old lip and the new decking at the joint.
From what I can see in the pics and by your description of the gunwales your boat looks/sounds like a very light construction (not heavy duty) and was more than likely designed to be supported by 2 part expanding urethane foam. I would strongly suggest using the 4 lb. density for extra strength and improved water resistance over the 2 lb. density.
ahmincha
Re: Deck coating
Re: Deck coating
Great jig I have read enough about the benefits of the foam to not be afraid of it haha. well let the cutting begin
ahmincha
Re: Deck coating
Re: Deck coating
Started the tear out
jigngrub
Re: Deck coating
Re: Deck coating
Describe what you have there Minch.
Is everything glassed in and solid? Is the foam dry to the bottom?
ahmincha
Re: Deck coating
Re: Deck coating
Thats as far as I got had to go to work the 1x12The 1x12 you see seems to have resin on the whole thing cloth on half and down to hull. The rear near fuel tank seems wet and there is some rotted wood I must have deleted the pic
I will post more pics as i do more work
ahmincha
Re: Deck coating
Re: Deck coating
Darn it I have to work tonight and tomorrow morning then back to the boat
ahmincha
Re: Deck coating
Re: Deck coating
Well I did a little on the boat there is no stringers in the front section of the boat as seen in picture in post th only thing that resembles a stringer is a small one down center of the hull seen in the second picture in post 68
ahmincha
Re: Deck coating
Re: Deck coating
There is plywood around the fuel tank that I out lined in red Is it possible there is no stringers
ahmincha
Re: Deck coating
Re: Deck coating
Port side next to bilge water on bottom Starboard side water at bottom port side water
ahmincha
Re: Deck coating
Re: Deck coating
The only wood i see is around the fuel tank and the 1 bys on top of foam
Woodonglass
Re: Deck coating
Re: Deck coating
This thing is looking more and more like a Whaler!!!
greenbush future
Re: Deck coating
Re: Deck coating
You can test the foam by using a 2 inch PVC pipe cut with some teeth to take a core sample right down to the hull. I didn't see evidence of water in your close up, it looked more like fuel leakage and a chemical reaction with your foam(black gooey area). You underside looks rather good compared to what most others boat look like. How the transom rot down deep where water collects in your bilge area? You have a very nice looking boat there!!!
jigngrub
Re: Deck coating
Re: Deck coating
Hey Minch, your stringers are the box stringers in this pic.
The 1x's are nailers to fasten the decking down to. Your hull and deck get a lot of support from the foam.
Since you have water and sludge/crud at the bottom of the foam I suggest taking it all out, then you be able to get a better look at everything.
jc55
Re: Deck coating
Re: Deck coating
You've been a busy beaver almincha!
Status
