'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
chasin-tails
Re: '78 Ebko Lebaron - Therapy
Trooper, I just finished reading your whole post. I wanted to read the whole thing before I replied to it. Being that I'm at work in Egypt for now it took me almost a week trying to read as I could. I have just got back into reading these since I have made up my mind to start on mine. I have been putting it off for awhile now but you have given me the oomff to try this out. My boat is alot different than yours but alot of the things you have done, I can use on mine. There is also another thread,http://forums.iboats.com/showthread.php?t=461659, by Swire that I have been reading. He has the exact same boat as mine but different name. I have a 83 ebbtide dynatrak fish and ski. I will be making it into a ski boat only with all the ideas I got in my head right now, I think any way.I have to say your thread is the best out of all of these I have read. You have given more info than I think anyone has. I don't mean to hurt any of the other guys feelings but it may be that I can relate to what you are saying being that you were a beginer when you started and a professional now. I sure appreciate guys like you that put it all in here for guys like me. You have done excellent and I can't wait to see it finished. I hope I didn't highjack or ramble on to much for ya'll.
Trooper82
Thanks Chasin-tails.....not sure that I would call myself a pro by a long shot...but I am getting to understand some of this.
I am glad that anything I am doing has helped anyone in anyway possible. Almost a year gone by now since I started the thread..I have learned tons...and still have alot to go! Shouldn't be too much longer before I am ready to try my hand at shooting gelcoat...that should be fun :)
Inspiriration of watching other's threads in here is what got me thinking...hey I can do that...with a little help of course...
I try to be short and to the point in anything I do...glad it helps...I'll be watching for you to start your resto thread...welcome aboard this crazy ride here too!
Troop....
Trooper82
500 or so miles of driving...waved at PMC again...6th time in the last 3 week...just about have the drive memorized....
Managed to get home with just enough daylight left to get this done...
plan is to get up early..do some sanding....can you believe I was missing the sanding? then once the dew dries up some more fairing...
Happy weekend all!
Now to go get caught up on what I missed this past week :)
jbcurt00
Welcome back, hope the road trip went well.
If I were to want a pack of pecans, that might be transformed into pie :), would the details be available via a PM?
saginawbayboater
Welcome back, I bet your trip was filled with the thoughts of your project. And the itch to get back, no pun intended!
have a good weekend to Troop!
GT1000000
Welcome back, safe and sound, Sir!
I am not the least bit surprised you missed sanding...I am actually looking forward to some grinding myself...:facepalm:
That is if I can get this tub right side up again...
Have a great weekend of boat progress!
Trooper82
SBB - yes I had the project on my mind quite alot in the evenings and the drive back...Thanks!!
Thanks GT and good luck with your flip!
Trooper82
slow start this morning...
took my wood sanding block I made and did some hand sanding...just to knock the high spots down...
covered in dust...
wiped off...
Now to make another few batches of filler...let it sure, then take the airfile to it...should put it pretty close to being complete....
jbcurt00
Didn't lose your touch while gone. :)
Looking good
Trooper82
more sanding....then another layer of fairing...
managed to pick up a few pecans while inbetween waiting on the air tank to fillup....and burned the pile in the back...wife mowed grass (just leaves really)..
good day....wasn't too hot either!
jbcurt00
So fall in Louisiana is sanding weather then :cool:
Looks great!
RE: PM thanks!
Trooper82
Trooper, What are you using as fairing material? Work is looking good.
Thanks...making my own...poly resin, mixed with fumed silica and glass bubbles...no one has complained about the recipe so hoping it is good to go....mixing till creamy then spreading.....I need to learn to put it down, smooth it once and the leave it be....trying to get it perfect and makes more work actually...but it sands pretty easy so it isn't all bad...
Railcar
All that glassing, sanding, glassing again, I bet you have thought you could have built the whole thing from scratch and had less work
Woodonglass
What kind of working time are you getting with the fairing material. I usually get about 20 - 25 mins. What are you using to spread it with...a bondo spreader??? On the Flat areas I tried to mix it a little on the "Ketchup" side since it wouldn't have as much tendency to run and it spread a lot easier and filled smaller cracks an pits better.
Trooper82
Guess I got about 15 mins...bondo spreader and a pice of that white vinyl sheet I got awhile back...as for consistency...it is spreading ok...and getting in the low spots...I may be going a bit heavy on the mekp..
GT1000000
I can tell from here your efforts are going to pay huge dividends in the finished product...Gonna be the "belle of the ball" when you get it gelled...
Trooper82
Thanks GT...efforts...airfile for maybe 5 mins...then walk around the yard with my pecan picker upper...holds roughly 5 gallons...have filled it up four times this morning...but...I almost have one side of the keel finished too :)
bear_69cuda
Checking in brutha Troop....
Lots'o work you've done my friend! I can almost smell the gel-coat! getting close dood!
