Re: 1989 Johnson 20HP "Quick help please! =)"
Good job!
Some water droplets are normal since the water tube is now disconnected.
Notice the rubber gromet in the pump housing, there is a copper tube up in the exhaust housing that connects to the gromet in the water pump. Grab that copper water tube, note it's position, and pull it straight down. Inspect the rubber gromet on the top of the tube.
There is also a plastic tube with o-rings that fits over the diveshaft. (Still in the motor midsection) Remove it also and inspect the o-rings.
Everything looks great so far.!
