northwoodslivin
- Feb 3, 2010
- 323
hello again guys
I am looking at buying a newer motor. It's an 89 Johnson 20HP short shaft. Couple of questions "may sound like dumb ones "
Does the exhaust come out through the center of the prop on this year? are parts easy to get in Canada? the fellow has owned this motor since new, said he put a new carb rebuild kit on it and a brand new prop and it has sat in his garage for the last 3 years unused. Do I need to worry about anything? He said the decals are scratched up on it as he used to stick his boat in his truck and put the motor in the boat on the floor. If I get the motor I would like to put new decals on it. Would any of you know where I could get a set in Canada?
Are these a good trolling motor? I must admit, I will be doing most of my trolling with the Minn Kota, but was wondering how slow of an idle these 20's will get down to? I know Johnsons are probably the best ever made motor "from what I have heard and researched that is " is this specific motor a real good reliable motor? Anything I should be looking at? He said the compression is excellent on it. Probably be picking it up tonight or tomorrow if I have some free time.
Your thoughts?
Your thoughts?
