1987 Starcraft islander 190v?
Status
Not open for further replies.
87Starcraft
a trick for plugging the hole behind the transom core:
  1. put a big chamfer on the interior side of the hole.
  2. give a solid rivet a healthy dose of 5200
  3. buck the rivet
  4. grind the bucktail flush with the transom skin; the chamfer will fill-in with aluminum that gets smashed down and hold the rivet in place even though you're grinding the protruding bucktail away.
Thanks classic. I was gonna do that just a bit unsure if I could secure a patch like that but I found a post in your thread showing you did that
87Starcraft
Wondering if my new one piece transom core will slide in like the three piece came out?
MNhunter1
Ensign
You'll need to remove your gunnels, fold up the ends, or cut the ends in order to slide in the new transom.
87Starcraft
I think this is a question for watermann. I can’t figure out how to get the gunwhales off. The cabin sits directly on them.
87Starcraft
Progress? I should of clamped these pieces together... Thought the big tub of water was gonna be enough.
Watermann
After the PMs and now looking at your transom set up pics, your splashwell style covers over the gunnels and the transom.
7511d6b2-dde5-4758-bff3-5936ffb202c4-jpeg.350131
The small strip (seen in the upper left of pic below) that you want to bend up can just be cut off or bent up and back down as it won't be visible once reassembled with the SW and caps.
9ed75255-ec52-4d02-b298-cd31ceec1feb-jpeg.352697
87Starcraft
Dry fit the transom yesterday. Looks like I won’t be able to put epoxy and cloth on transom unless I cut a quarter inch off the stringers.
87Starcraft
Gunnels trimmed out of the way
87Starcraft
Does anyone have pictures or methods on how they attached their sacrificial anodes?
Watermann
Not sure I've seen anyone use anodes other than what is on the motor/outdrive. My Islander has one on the transom but I doubt it did anything since they put it on paint and then painted it. You can see it in the pic above the bilge drain.
y4mePhMG0VxE1dSaDQBWPGafxKPLuznISL-K677uc_GLlv4WzFFUgaAR0bnvHyfC8TAxj3Teyg7CGHGIWPVqYSd0X9a229ZjaL2Y9ODbqgbr5kVdJpLTA3x2EVNfANS3Yeb3xY63lLxF27vOxGQ7350MRDbDtIfIrQnHdI890RzptVFKJB9k1odV0KvddDcFOdD
87Starcraft
I was wondering. I could hardly find any info on here about anodes. I had one attached where the stringers meet the transom. Just wanted to prevent corrosion but this boat is definately a trailer queen
87Starcraft
Good morning everyone,
I have been picking away at the islander here and there.
I got the transom done. I did exactly what classiccat did and epoxied with fiberglass cloth, drilled oversized thru holes and used epoxy with cab o sil. I then painted the side that will be exposed to the sun with farm paint from tractor supply with a hardener. And this is the result. Gotta say I’m pretty happy with it. It feels like a piece of granite.
classiccat
"Captain" + Starmada Splash Of The Year 2020
lookin' good 87! it's a little more time & expense but totally worth it. The aluminum will rot out before that transom does! :LOL:
87Starcraft
It was a fun process. I’m glad I went that way. I have a couple epoxy projects in be been scared to do, not now. U.S. composites seems like superior product over west systems.
Status
