SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Thread starter- Joined
- Mar 8, 2017
- 1,780
If i remember right it was several days
Man I wish!!!!!! Admiral and I are on Month 2 of riveting....
@jbcurt00
Can you please move this thread to the Starcraft Rebuild forum?
Thanks
SHSU
Moved
Just to be clear, this was in the Resto/Rebuild forum. This is the Starcraft Owners forum, so there may be a glass boat or 2 as well. Some (many? most?) SC owners choose to document their resto here, esp the tin boat fellas
Either forum is a good place to document your work.
Occasionally, even though they are active members, some tin boat guys will miss a new boat/rebuild/topic because its in the main resto forum, rather then here.
W the current vB5 forum software Todays Posts feature, I use that new posts list as my bookmark for iboats, and rarely go the the main forum or any specific forum/sub-forum homepage. So no matter what forum, if a new post is made in ANY topic ANYWHERE on the forum, I see them listed in the Todays Posts list.
Unless I go 24hrs w out checking in, I dont miss many new posts or the updates to that topics.
You asked for it. :lol: I have a couple questions. Why would anyone care if unseen aluminum oxidizes? Why do so many people think pick up truck bedliner is the savior of aluminum boats? Bottom line is bedliner will fail and it can cause serious corrosion issues when it does.
The entire bottom of my SS is bare AL and it's a beautiful natural oxidized aluminum gray color now.
Knee brace looks well done :thumb:
A word of advice, don't bore the holes through the KB until you dry fit the transom wood and mark or drill through all the holes.
Both my SCs have that style of drain plug, they work fine. The only other option is a garboard plug style and most of them are dissimilar metal used in glass boats.
Attach the KB foot to the bottom then, insert transom wood, drill the transom and clean KB at the same time. It's just so you don't have to worry about aligning the holes.
I give my advice and suggestions on rivets in the rivet sticky. AL/AL and another thing is SS would cost 3 times as much as AL.
http://forums.iboats.com/forum/owne...-boats/10435722-rivets-rivets-and-more-rivets
1/4" blinds only come in dome head as far as I know but you could use them I suppose at more cost of course.
I used the 3/16th for the floor. Plenty good enough. Make sure you get long enough rivets for the job! Also double check length if you are going thru carpet covered flooring etc. Stainless rivets are a pain to drill out and are very grip range fussy. I've had them not pull the joint/seam tight if a tad too long.
In the rivets sticky the blind rivet lengths listed for each decking thickness takes into account the deck covering and the material below deck they're attached to. Are you going to run the LF rivets through the carpet leaving the heads exposed? If so go with the listed rivet length for the decking thickness you're using.
