SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
- Mar 8, 2017
- 1,744
So that Admiral and I put in an entire weekend. Sent the kido off to the grandparents and started with a vengeance on finishing up the ribs. Happy as Hell to say that 99% of all the riveting that will need to be done has been completed. YA!!!!!!!! Still have to do a couple things like the transom rest, the knee brace, the side shelf and 8 rivets under the rub rail; however, calling it close enough. I can at least start to move on and tackle other parts now. As a note for anyone that is thinking about re riveting a hull here are a couple stats:
Number of Rivets on 16ft Starcraft Supper Sport: ~1700 (I ordered 2000 3/16 and 100 ?)
Waste you need to account for: ~170 (Or 10%)
Tubes of 5200: 3-4
Rivet Gun: Harbor Freight/Amazon specials will not work?. Need a true Aircraft Rivet gun
Bucking Bar: 2 (2lb and 6LB)
Rivet Set: 3/16 and ? brazier head
Helpers: 1 willing helper or a pissed off admiral because of the noise/sweat/mental toll/physical toll (Sometimes one and the same)
Drill bits: 7 (You will break them and dull them out) or have a Drill Doctor
Hearing Protection: Admiral and I had some cheap ear muffs from HF with our Bluetooth headphones and audio books going to help reduce the noise. Even then, when riveting you could barely hear the book
Time: 2 Months? worth of weekends.
As an example: prep time for 5 ribs took 3-4 hours before riveting began. That includes: drilling out each hole, using grinder with wire brush to clean underside of rib and hull, realigning, vacuuming and clean up before moving on to next rib. Each rib had 21 rivets per side. Meaning 42 rivets per rib and there were 13 ribs.
Estimating 30 seconds (high side if just riveting only) a rivet that is ~15 hours? worth of riveting. Doesn?t seem too bad until you consider: drilling out each rivet, cleaning the hole, prepping hole, adding 5200 to each hole, placing rivet, setting rivet. Verifying its good, if not, repeat previous process. Or, doing an entire rib and the realize that you forgot to do the rivets under the rib that you can?t get too without the rib removed?
In the end, I would estimate 100 - 120 combined man hours of work being done to re rivet the entire hull
If you can get through all of that, you can have a completely re riveted boat (99%)
Interior
Update: 08/17/2017
I have taken off the gunwales and redone all of the rivets there as well. I realize that I will need additional 3/16th rivets. I ordered 2,000 and am now looking at ordering an additional 100-200 to finish everything out and have some extra. So anyone that is tracking:
Initial Order of Solid Rivets: 2,000 3/16 x 1/2
Additional Order of solid rivets: 100-200 3/16 x 1/2
Initial Order of Blind Rivets (200 Hundred each for a total of 600):
3/16 x .626-.750 Dome Head
3/16 x .876-1.00 Large Flange Head
3/16 x .126-.250 Dome Head
Additional Order : 100-200 5/32nd x .126-.250 Dome Head
Tubes of 5200: 3-4
Interior
Update: 08/17/2017
