What do you pull your boat with?
catgo22
Re: What do you pull your boat with?
Pulling a '97 Chaparral 21' with a '03 39' Fleedwood Discovery with a 330hp Cat. Need a little bigger area to turn/launch but pulls it like a toy. Throw a wheel chock behind the rv duals just to make it a little less scary. Rv tail is long enough that the rear wheels and exhaust never get near the water. Use a scooter to get around.
alloffroad
I tow my 17 foot bow rider with an 05 dodge durango with the 4.7 liter engine. Hardly notice the boat trailer
Urbina
i tow my glastron with this.
cruises like a Cadillac
idahoelk
Relatively new here but here's mine - 1994 Blue Water 22' Marquee pulled by a 1999 Ford F350 crew cab 4x4 with a 7.3. Might be a bit much, but it pulls my 4 horse trailer without 2nd thoughts also.
Theeplaymaker
Pull my 16' bass boat with my 2000 Dakota with 174k on the clock...5 speed with the HD trans aka lower 1st and 2nd gear and 3.92 rear so it does pretty good, pulls better with the Superchips on Tow Mode than regular economy mode. I definitely have to do the front brakes that have been on it for 5+ years though because it doesn't like to stop as good as it should.
Ryanlewis2010
ya those beast pull, is yours a dually? im running the same setup and year. it never thinks twice about pullin me up some of my steep ramps
billyman
I pull my 2004 Bryant 214 w/ a 2005 Toyota Prerunner w/ the factory tow package. It's rated for 6500# and I guesstimate I'm right around 5500#. Since the ramps I frequent aren't steep and in really good condition I don't worry (much) about launching from them, but I really stress at the thought of visiting an unknown lake. If my truck was 4x4, I wouldn't worry much at all.
For the record, I have also pulled 2 1999 Polarix SLX jetskis, 1996 20' pontoon w/ 70h Suz 4S and a 2006 Monterey 180FS w/ thjis rig without the least bit of trouble.
RamAirZ
I use my 2004 GMC Sierra 1500 as my tow rig. Rated for 9500lbs, has the factory tow package with in-dash trans temp gauge, 3.73 gears, pulls everything I need. Eventually I want to end up with either a crew-cab 6.0 Ford (thinking orange/tan King Ranch edition) or 98ish crew-cab Chevrolet with 6.0 LSx engine swap (or maybe a Cummins conversion lol).
tow rig:
Jerryh3
A Tacoma? I thought those topped out at 5K?
tcindie
The couple times I've towed my 14' Larson Playboy has been with my Chevy Aveo.. looks a little silly since the boat sits a lot higher than the roof of the car, but it's not been a problem.. Even the one time I dunked it in the lake and she took on a bunch of water. The car hopped around a little getting her out, but I still managed it just fine. Figure that was probably a good 1000lbs extra water weight
kenmyfam
Maybe should have bailed it out first ????
kenmyfam
Same tow rig, new boat to pull.
greekfreek
I pull my 2010 Larson 1850, 18.5ft with a 2010 Honda Ridgeline, 3.5L V6, 4WD. Tow capacity is 5000lbs...It does OK..
ronsealdeath
A 2002 Ford Mondeo Estate (Wagon) 2.0 TDCI (turbo diesel) 5sp manual. Rated to tow 1800kg (4000lbs) with my setup weighing circa 750 to 850kg (1600 to 1900). 17ft Microplus 501 with 50hp Merc (1990) plus aux, fuel and other stuff. Front wheel drive never had an issue, got winter tyres up front, all weight is over them, its got 244lb ft and 130bhp so all good.
I'm in the UK.
My3kidsmlc
I pull my 1988 sea ray mid cabin with my 2006 Dodge Ram 2500 4X4. Pulls just fine down road, total weight between boat and trailer is 5000K roughly.
Water logged
2006 Sea Breeze LX 35 ft motor home or 2011 Chevy Colorado 4X4 pulling my Party Barge 22 Sun Tracker Regency. The motor home is about maxed out, 1500 lb left on Colorado.
Glenn
RMasters
1999 Ford E-Series 150 van with V6 engine. Rated to pull 10,000 pounds. V8 5.4 only does 2,000 pounds more. I hardly notice that I have something behind me.
wbh3569
My new to me 2006 F-250 with 6.0 PSD pulls my 24' Maxum like it's not even back there. By far the best tow vehicle I have ever owned. Replaces a 2002 Ram 3500 with V-10 that crankshaft broke @ 113K miles.photobucket-4088-1334319917387.jpg$(KGrHqFHJCkE7y3YzuT!BPEc8Z3rvg~~_4.jpg
tomstehr
I pull mine with a 2007 Chevy Silverado with the non-flex 5.3 liter. It pulls my Javelin 379 FS pretty well the places it's been so far.
