I pull my 25ft skip jack with my 1990 Ford 4x4 F350 turbo diesel. All this truck does is tow. This is the 3rd boat in it's lifetime that I have owned and it has towed, Each one gets a little bigger and heavier. It never complaines so I'm going to keep it!
Might as well keep it, one of our crew trucks (99 F250 7.3 6spd 2wd) went 800K before it broke a connecting rod. We rebuilt that engine and that truck should go past 1 million miles next summer.
I know, the only thing that killed the 7.3 was the EPA.Wow. Thats awsome talk about getting your money out of it.
and then they gave us the 6.0 and everything killed it, just sitting it would break...... (but I'm still drivin it)
nice rig!
I like the way a 6.0 pulls, they're quiet and get better mileage than the 7.3. But every one I've owned had major problems. My personal truck has the 7.3 with 300k on it. And I have a newly rebuilt 7.3 on a pallet in the shop for whenever it breaks. I hope one of the big 3 will come up with a better option in the future. I'd buy a gas burner before anything available in diesel today. JMO.
I would agree, a 12 valve Cummins is hands down the best light truck diesel engine. I've had a local shop do $5000 in mods to a 6.0 F250 work truck, studded heads, EGR delete, coolant filters etc. etc. and even with no tuner at all the dang heads lifted. That was it for the 6.0 for me. My friends with 6.4's tell me it gets 11mpg which defeats a big portion of my motivation to own a diesel. And I don't know much about the 6.7...but after the 6.0 and 6.4, I'm now a skeptic.If ya replace and modify a few things on the 6.0, the only problems the 6.0 will give you is injectors. But if you are a stickler for oil changes and typical maintenance it will be few and far between that it even gives you that. The 6.0's are good motors, run great when they are running good. Ditch the EGR cooler, update the oil cooler, add a coolant filter and a few little things here and there and it'll be almost bullet proof as long as you don't run a big tune on it (there just aren't enough head bolts, and even with studs it'll still lift the heads on big tunes with alot of boost). The 7.3 had it's share of problems too. CPS's, fuel drain leaks, under-valve cover wiring harnesses, wastegate actuators, lift-pumps, injectors, TPS, etc. Ya it saw less problems from the start compared to a 6.0 but in reality it still experienced ALOT of issues. As for the best diesel, a common-rail 5.9 or a 12-valve cummins are the best out of the box options, and a 98-03 24v Cummins with updated VP44 pump and FASS or AirDog system are still good, and you can still convert them to a P-Pump which will make them even better than the early 12v. I work on these trucks everyday, and ALOT of 6.0 fords, but when we get one in, we usually get the customer to upgrade all the crap stock parts and eliminate alot of the downfalls to it. Working on them for a living, I'd own one over a 7.3 any day of the week. The 6.4's are really nice and the 6.7's are good too as far as Ford's, but still, the Cummins rules the roost IMO.
Much of that has to do with purchase price, Ford is usually the cheapest and for most companies and municipalities, that's the bottom line.Cummin=Great motor
Dodge=weak tranny and poor engineering
I will say they have eliminated most of these problems now. With new diesels you can't go wrong with a cummins or a stroker. The 6.0 was designed to target commercial customers and it did very well. have you ever noticed how many diesel company trucks are 6.0's and how many are dodge/chevy...
Anyone here tow with the Ford Ecoboost f150? Hows the gas milage and what do you tow?
Around here, diesel trucks don't have emission inspections, I know several guys that have removed the EPA garbage from their 6.4 trucks and the mileage and power increase is pretty impressive.A co-Worker of mine has one, he loves it. Considering the URIA tank on the new Ford/ GM diesel and the poor MPG they are all getting due to emissions, the Ecoboost is the way to go IMO.
