Top Secret File (UPDATED 7/13/2017)
Status
Not open for further replies.
tashasdaddy
Disclaimer
iBoats has no control over external links contained in stickies and to be aware that links are fluid and may or may not work.
This Is Under Construction. just click and get the answers.
these are suggestion, NOTHING beats the OEM manuals!!!
Classic Johnson/Evinrude service manuals; wire diagrams; and more free! verified 11/12/25
WIRING DIAGRAMS For Johnson/Evinrude verified 11/15/23
1962 - 1970 Repair Tips Regarding Lower Unit Electric Type Shifting That Jumps/Slips Out Of Forward Gear On Select 40, V4 75, 80, 85, 90, 100 HP. Verified
ETHANOL, FUEL LINES and CARBS Link still busted, Restoration in progress
WHY WON'T IT START Link still busted, Restoration in progress
COLD START PROCEDURES. Verified 11/17/23
IT HAS BEEN SITTING 2 YEARS, WHAT TO DO? Link still busted, Restoration in progress
Ignition Switch Wiring Diagrams Verified
HOW DO I ADJUST MY CARBS? Link still busted, Restoration in progress
Carb Cleaning and rebuild Link still busted, Restoration in progress
Joe Reeves TIMING Johnson Evinrude Carbed motors Verified 11/18/23
Trim N Tilt won't work??? Link still busted, Restoration in progress
PRIMER SOLENOID ( red handle) Verified 11/18/23
POINTS AND COILS verified 11/17/23
Starter will not engage, or will not turn motor. Verified 11/17/23
SHIFT ROD HEIGHTS FOR LOWER UNITS. Link still busted, Restoration in progress
Decarbing Motor Verified 11/18/23
Changing Lower Unit Oil Link still busted, Restoration in progress
compression test by JB Verified 11/18/23
Removing Flywheel Link still busted, Restoration in progress
Winterizing Link still busted, Restoration in progress
Lower Unit interchange Link still busted, Restoration in progress
what year is my motor?? Link still busted, Restoration in progress
WATER PUMP, and Lower unit, tutorial, many pictures. Link still busted, Restoration in progress
Maintainance schedule Link still busted, Restoration in progress
pressure and non pressure tanks Link still busted, Restoration in progress
VRO conversion questions Link still busted, Restoration in progress
Salvage yards Verified 11/15/23
Universal magneto troubleshooting Link still busted, Restoration in progress
Mod-Edit. As we fix things above, the links below have been verified in August of 2021. Should any member of the community have a link, feel free to report this list, and past the URL in it. Thanks .....your moderator team
Evinrude Engine/Engine Gasket Sealers List Verified
for the ethanol fuel line and carbs, it will be one of these https://www.google.com/search?q=ETHANOL,+FUEL+LINES+and+CARBS+site:iboats.com
boat sitting for two years will be one of these https://www.google.com/search?q=IT+HAS+BEEN+SITTING+2+YEARS,+WHAT+TO+DO?+site:iboats.com
primer solenoid
points and coils
starter will not engage
Manuals and diagrams
changing oil may be one of these
compression test
removing flywheel may be one of these
installing cables
winterizing may be one of these
lower unit interchange
cold start proceedure
what year is my
pressure and non pressure tanks should be in here
VRO conversion should be in here https://www.google.com/search?q=VRO+conversion+questions+johnson+site:iboats.com
Status
