1970Thunderbird
- Dec 24, 2009
- 111
Hey all,
I just got my block back from the machinist and I'm ready to start putting her back together. While I was visiting with him, he suggested I sand or bead blast the exhaust side of the block, including the water jacket cover, to remove the carbon deposits. What do you guys think? I'm a bit worried about doing this, as it's aluminum, and I don't want to etch or mar anything.
Also, the bolts on the crankshaft end of the piston connecting rod face into the block, meaning they are only torque-able while they are outside of the block. So this means I have to fit all four pistons at once. Do you have any tips for how to do this? Also, will standard ring compressors from Autozone work?
Also, the machinist recommended thoroughly washing the block with soap and water to get all the machining grit out. Any extra steps I should take to ensure the block is completely clean before fitting the pistons?
Any tips you have would be greatly appreciated.
As always, you have my deepest thanks
