Re: Took the head off my motor, heres a video explaining everything.
riptorn you are correct, most of the bolts need to be polished, on one of the first videos I explained how I polished the head bolts and I will be doing the rest of them prior to rebuild. Pnw, I bet you are right about never putting those retaining rings in, the upper one was gone, it almost looked as if it melted into the piston, but I bet it was never there in the 1st place. So now I would like to find where I can buy replacement floaters instead of putting pressed pins back. The pin on #4, granted it had no rings holding it in place, but I literally pushed the pin out with my finger with virtually no effort. Also, I just dropped off the block at an engine machine shop, they have to replace the sleeve afterall, its going to be $300 in total for labor, new sleeve, removing broken bolt, honing all cylinders, and cleaning the block. Sounded reasonable to me so I left it there. Otherwise it was going to be $100 for the bore. I should have it back in about a week. Since I'm getting a new sleeve I'm sticking with the stock size so I can get a set of 4 matching pistons. I had to remove all the lines on the outside of the block so I guess I'll need to see about getting new ones also. I suppose my best bet is to wait til he is done with the block before I order any parts. I also showed him the head and asked if he thought it needed machining or resurfacing and he said it looks good, thats what I thought so I'm happy about that.
