Re: To Build a Boat (any boat)
The floor is 3/8, the sides are 1/4, and the transom is 1/2", reinforced with bracing. Due to the expense and difficulty of finding AC around here, I've had to go with BC and lots of sand paper. <br /><br />The construction of the boat doesn't require resin, but due to its intended use, I'll be soaking the entire boat in poly resin and adding a light layer of cloth to the bottom and a couple inches up the sides I think since it may stay in the water some. Haven't decided what paint to finish it with yet either....<br /><br />After restoring two 'glass boats, this should be a nice change of pace.<br /><br />I couldn't let Wimp have all the fun here in chilly Tennessee could I??? <br /><br />Hmmmm,, maybe I need to build a Mini-Max for my 20 and challenge Wimp to a drag race since he's not far away....<br /><br />Actually, I'm thinking about something like the Glen-L Squirt. just what I need....3 boats. I already have the 19' I/O and 15' tri-hull. I want something fast that draws little water for my 20hp. I have to travel nearly an hour to wet the other two. Somthing like the Squir could run in my local river.....
