Pcolafisher
- Jun 26, 2013
- 188
Sorry, Cheers!
Welcome aboard CaptNewbie. Restoring one just takes a lot of patients!
So....That's where you get all the money to restore these boats...DR. Archbuilder and his Patients!!! I guess I need to have more patience with you!!!!!
I have been working on the wiring, nothing to exciting to see yet, mostly planning. I did spend a good part of today laying out the dash and sorting out the clearances with the steering rack
It is naturally right in the sweet spot for gauges and switches. After a lot of measuring I got everything laid out on the template. This is chipboard, about 1/16" thick, works great for stuff like this.
I was worried about the switches, seems like cutting those holes are the hardest since they are square. Turns out the depth gauge on the upper left proved to be the pain. There were some air pockets in the layup and they chipped out when I drilled the hole/ That is really irritating at this point....if I would have only drilled the gauges and switches before paint. I've been pondering having a fiend turn some bezels to hide it....I don't think a paint fix will look very good at this point without a lot of effort. So I'm going to ponder that tonight. I need to get screws for the speedo, right lower hole and a ignition switch with a longer shaft, left lower.
