drewpster
- Oct 17, 2006
- 2,059
Re: My tri-hull transom replacement w/ pics
Epoxy is expensive, but it bonds much better than polyester. If you go with epoxy you wont need as much fiberglass or as many layers. Any woven cloth would work, it depends on how much thickness you need. Go with the heavier weight if you need more bulk. I would go with the lightest your are comfortable with.
Polyester is also good and half the price. On a deck I would use 1.5oz CSM and 18 oz woven roving.
If you go with epoxy forget the CSM and use cloth.
Epoxy and poly have different processes. Make sure you know how to use the one you go with.
