Re: my 1991 capri rebuild
next i filled the gaps around the subfloors and used a large pice of 1708 to skin the top and tab them in nice and solid
same shot, just from the other side
then i cut open the drainage slits, did some sanding, cleaned it down with acetone and put the first layer of gelcoat on heavy
after the second coat i used the pva mold release stuff i got from us composites to get the gel coat tack free in the tank area
i didnt take a picture but after this i took some mat made from recycled rubber and cut angled strips and glued them in the fuel tank area. i then placed the tank in and cut the first section of floor that goes over it. i coated the bottom in csm and then painted it with gelcoat to just protect it since it will be a moisture rich area. that first layer is being held down with PB. it was getting dark at this point. i also decide to do what friscoboater did and use redgard where i am going to foam.
i began rushing at this point and was tired as i painted the redgard in the forward areas and forgot to use the pva in the ski locker area on the gelcoat, so ever bit of dirt on my shoes came right off and stuck to the gelcoat, UGH.
today after work im going to sand down the dirt and get that out and put a last coat in the locker area, then i will actually remember to spray or paint the pva on this time.
during the week days this week i hope to get the floor cut and get csm on the underside so i can install it this weekend
