bleedblue94
- Oct 11, 2010
- 272
Re: my 1991 capri rebuild
thanks for the compliment. im curious what is your concern on the weight? ive only added minimum weight by widening the transom. i think when this is all done even with whatever i add to this boat in structural weight and the upgraded motor will be completely countered by the rot and water weight removed
I didn't get a chance to read the whole thread completely but you are doing one hel of a job. I tip my hat. I did the same with an old 16 ft Humber 25 years ago. No comparison with a Capri. A lot of work man.
Just curiosity, did you weigh your boat before you stated your project? I use to build sail boats back in the early 70's and learned that too much weight could compromise the speed and balance of the boat. I am pretty sure you took that into consideration.
Good job
