- Jul 18, 2011
- 19,481
Re: Formula 330SS Bulkhead Replacement
I found my pictures of the forward bulkhead and mid-cabin structure. The bulkhead does stop at the main stringers, so I could take it out and replace it without concern about structural integrity. However, I would have to tear up a bit of the mid-cabin floor (so it is called, actually a storage area).
My only concern is if the forward bulkhead is getting moisture 'fed' to it from saturated foam in the sole of the mid cabin section. I should probably drill into the sole/foam area to inspect/test the foam for moisture. If it is good, then maybe just treat the bulkhead and be done with it.
if I keep the boat for a total of 10 years, it will be 2022 and the boat will be 26 years old. Probably will be at its 'residual' value for sale or trade.
