Deck coating / Turned complete restore
Status
Not open for further replies.
ahmincha
Re: Deck coating / Turned complete restore
Ok I over sized all the holes in my transom then filled with pb also filled the low areas on top of transom hope to tab later today after work I also filled the strake I think there called so my tabbing will lay flat less contours
SAT_Bob
Really nice work! Keep up the great progress.
ahmincha
The next one looks challenging hope I am up to it
ahmincha
That was tough I got a couple air bubbles but all in all I think its good will see when it sets
tallcanadian
Sooo, what do you need us for? Great job. Very nice work on the transom. I can testify, as you go along you will get more comfortable with the resin. Thanks to Wood, I found it easier as I went along. Looking Good, man..
ahmincha
Thank you tc. If it was not for the help here ESPECIALLY wood I would never attempted this Thanks to everyone
Woodonglass
Did you use the bubble buster roller? All in all I'd say for someone that I KNOW had to be a bucket full of nerves that's a pretty good lay up. It WILL get easier and better!;)
ahmincha
Yes I did but I mixed at 1.5% and it started to set up some of it is reflections but there is some air bubbles.I guess I grind them out and put patches over them? That was a big piece with a lot of contours and I have to do it again oh boy
Woodonglass
Yep large areas are a challenge. You learned a lot from the first one and it will pay off on the second. Dremel the bubbles and patch em and move on. I'm bettin' layer two will be darn near perfection!!!:D
ahmincha
I hope to get this repair tomorrow it looks like 2x material can I use a standard 2x4 for this also these look like standard 1x material wich I am replacing I assume standard 1x material
Woodonglass
I agree with your assessment. I'd do the same. A little PB bedding and then CSM or 1708 to encapsulate them in place.
ahmincha
Thank you have a good night
ahmincha
all ground out . Can I go over the areas with pb to fair them out then retab the whole thing
GT1000000
If they are not too deep, you can cut a few patch pieces of CSM and save some resin...although PB will work, too...
ahmincha
Thanks gt some were a little deep I plan on fairing the majority so the next layer ill be easier
Thanks tc appreciate the encouragement
Status
