Woodonglass
Honorary Supreme Mariner
- Dec 29, 2009
- 25,933
A bit odd but nothing to worry about. I LIKE your little helper!!! Does He/She have a LITTLE Dust mask Too!!!:lol:
Hi Barra boats looking good
Its a shame your not a lot closer ya know like bowen, id drive up & help just for the fun & experiance
Think yur po maybe the same as the bot we were going to do the new floor they installed was screwed st8 thu the hull just by your yellow line with 20 stainless screws![]()
Great progress Bar! Looks like you have all your demo tools in good control. Excellent! Cool dog looks like part Corgi wire hair.
I could have done so much more if I had a saw. Now I have to go make some money to help pay for it...Buddy is part Maltese part Jack Russell
I'm not much of a saltwater fisherman, but IMHO it looks similar to an Ocean Striper, kinda sorta..Maybe without the stripes??![]()
Looking good. On the keel you can run a grinder with a metal cutting wheel. Cut on either side, slice on the top then you should be able to "peel" the glass off to get at the keel stringer. On the two left over just run a sawsall blade along the bottom then pick /cut out the rest. Then the grinder again to cut the stubs down to the hull.
if you drill like a 1" hole just above the floor into the stringer then you can just put that sawsall blade right into it and go down the lane with it. And on the same note...Most builders are like thorns on a rose. They always Prick you. Especially at the end of the job. It's the same here. You have to thin your herd to only the good ones. Good luck! Here in the states whoever has the most $$ to wait you out usually wins.
Cool on the tank and pod.
