redneck joe
- Mar 18, 2009
- 14,467
Re: 87 bayliner refurb/restoration project... "The Big Dirty"
good luck. I got no bail money for you....
A seat on the Titanic would be more safe.... do you really think you will feel safe on this rig?
.... better to find out early, before anymore cash is in it....im sure you could salvage some stuff..
........ If you can pull a tranny out of a mark3 Jetta on your back then you can push on with this project. You have the "mad skills" in your blood. I say push on my Bayliner Brother.
....these bigger boats tend to be dirt cheap in need of lots of work, or stupid expensive, ready to go...
I made the choice to carry on, knowing I needed to replace my obsolete engines....but im a damn the torpedos kind of guy...
Big D. Great Idea, all is not lost just yet. Have you had this pig running in the past? As long as that motor hasnt been ran with that water in it is should be fine.
Got any pics of the motor and these gaskets that are "pushed" out around the pan?
Ok, got a few pics today.. The port side pics (first 2) may be hard to tell as to the pan gasket leaking or not, but you can probably see the oil marks on the bellhousing, dripping from the middle/center of the motor. Starboard side (yes that rusty 'thing' is my starter.. a rebuild was planed) you can see the oil glistening from the camera flash all along the pan/gasket area.. for comparison, the last pic is the block, which appears fairly clean and is not covered in oil
.... i would be putting a wrench onto those oil pan bolts and snugging them up. you can see the oil hangers off the bolts.
I really dont thing your rear main is leaking. Most rear mains only leak when the engine is running and not when it is just sitting there over the winter...
