Yeah, primer shows EVERYTHING!!! If you really want to get anal, sand down the bad spots and fill em with some JB Weld thinned with epoxy to make it a bit more Creamier and easier to smooth and sand. Make sure to keep shaking the can. The primer SOLIDS need to keep being mixed. They tend to want to settle out of the mix!!! Looking pretty good though.
:clap2:
Like Frisco Boater said, "you learn how to do something after your almost done" :facepalm:
As always your spot on, I noticed the way it layed down kinda spotty sometimes and not smooth. Didnt occur to me that I didnt mix the can well enough Doh! I had attributed that to the weather being in the low 30's
Im going to examine each piece for imperfections and sand them out. Everyplace else gets scotch brite only. Divets and craters will get filled when i add a layer to the shark bite low spot. When you say epoxy do you mean like from harbor frieght? Also, what is the ratio of JB Weld to epoxy? or is there a good starting point ratio?
Also, my 50 50 mix of acetone and mineral spirits came out kinda oily, is that acceptable or "normal" ?
